April 28, 20242 yr U5 box, Loaded credentials and channels or vod not working...a lot of 'spin' and no action. Any suggestions would be appreciated.
April 28, 20242 yr Any error messages ? MAC or XC type login ? ie: Did you just give your MAC address and they provided you just a portal URL, or did they give you a portal URL and username/password ? What version of BuzzTV 5 are you using ? Hit Menu button from the LiveTV app, and you can see the version number on bottom left (5.0.xxx). Do other apps work ? Like youtube ? Can you play a video through the youtube app ?
April 28, 20242 yr Author XC login No error message Did not try YouTube....was trying to get the TV stuff going. I put my old box back up....until I can get some ideas....not sure the version.....will check
April 28, 20242 yr Reason I ask for youtube is to make sure that the internet connection is actually working on the box. Just checking the basics 🙂 Latest "public" version I believe is 5.0.919.
April 28, 20242 yr Just now, Emporium said: Reason I ask for youtube is to make sure that the internet connection is actually working on the box. Just checking the basics 🙂 Latest "public" version I believe is 5.0.919. From LiveTV, go to menu->setings->check for updates (or something like that - not in front of my box right now).
April 28, 20242 yr Author Version is 5.0.919 It is connected as I was able to log into my IPTV account
April 28, 20242 yr have you restarted your box since you got this problem? if not try to reboot please
April 29, 20242 yr Author Ha....I had turned it off, but I just unplugged it and that seemed to work....thanks
April 29, 20242 yr 5 minutes ago, Luc said: Ha....I had turned it off, but I just unplugged it and that seemed to work....thanks Now you know what I asked if youtube was working 🙂 Do yourself a favor. Change the "powerkey definition" to shutdown, instead of "suspend" (if I recall, from home screen, go to settings->more settings->powerkey definition). Yes it takes an extra minute to power up, but at least it is a clean boot all the time. not just waking up from a suspended state.
