Wi fi location service will not turn on.
Some apps are not available to download because not available in my region, not good, thanks
Your box has wifi location service and will not engage for location to download apps from different regions like I am in Canada and your box tells me cannot download apps because wrong region, probabley google service doing this.I have a vpn.
That is not a Buzz problem that is your VPN problem turn it off and and download your apps or change location closer to you
use aptoide or side load. your box is open and willing to take however you like to transfer/install.
From main menu, if you go into settings, and select "location" you can turn it on if you want.
I just don't see the point.  Use Aptoide store (as mentioned by Ryu), or sideload anything you want.
I'm in Canada also, and have no issue installing any app so far.
