Flashdrive and VLC
When you launch VLC, if you scroll down, you will see your USB device and you can then browse it and play whatever you want.  I do it all the time.
However that assumes that when you first launched VLC (when you got your box), you gave VLC permission to access files on your device.  If not, you may need to play with permissions (or just uninstall and reinstall VLC and then accept the permission request when you asked at first launch).
