Remote
I had to do a reset of my st-4000 vidstick and its asking to pair and it will not pair n using the OK and vol down buttons. the screen says
SEARCHING...and never pairs. the LED is flashing red and the IR is connected. just wont pair. is there any way around this bluetooth pairing?
use IR to go to settings and remote and accessories, and see theres option to add accessories and try from there and see if that helps.
