September 22, 20233 yr Hi all. I hope you can help me with my problem. As the title alludes, my unit freezes, plays a second or two, freezes again, plays a couple of seconds, freezes, continually. On most channels. I only watch rugby (South Africa and New Zealand channels) and news channels, but it's doing this for all channels. I've restarted the box over and over again. Thank you for your help. Incidentally, is there a tips and tricks thread somewhere that I can peruse so that I don't have to start a thread for each issue? Thanks again.
September 22, 20233 yr you don't mention your download speed at the box do you have a hard drive plugged in the base?
September 22, 20233 yr Author I have checked for the latest update and it said the current version is the one in my system. I don't have any thing connected to the box except the tv. I don't know how to measure download speed. I've wanted to add a hard drive so that I could actually have the recordings of the things I have recorded but haven't done so. Thank you.
September 22, 20233 yr 46 minutes ago, neanderthal said: I have checked for the latest update and it said the current version is the one in my system. I don't have any thing connected to the box except the tv. I don't know how to measure download speed. I've wanted to add a hard drive so that I could actually have the recordings of the things I have recorded but haven't done so. Thank you. Post what firmwate and software version it is Edited September 22, 20233 yr by nbs.
September 22, 20233 yr 1 hour ago, neanderthal said: I have checked for the latest update and it said the current version is the one in my system. I don't have any thing connected to the box except the tv. I don't know how to measure download speed. I've wanted to add a hard drive so that I could actually have the recordings of the things I have recorded but haven't done so. Thank you. in livetv press menu and look for software version at the bottom if it's not 5.0.893 then press settings/check updates to test speed go to app store(aptoide) or google play store and download analiti
September 22, 20233 yr Author In settings i clicked about, and then scrolled down to where it said: kernel 4.9.113 Version 9 build V20220919 I hope this is the information you need.
September 22, 20233 yr 58 minutes ago, neanderthal said: It says "latest update installed." in live tv press menu scroll to settings scroll to check updates I promise you it wil not say "latest update installed." because that's impossible there is a difference between firmware and software
September 23, 20233 yr Author It gives me a small pop up box at the bottom of the tv that says "no updates available." I tried it 3X and even took a video that I can send you if you want to see it.
September 23, 20233 yr Author I tried signing in on my phone to see if I could post the video here, but couldn't remember my password and it locked me out for 15 minutes. I have a meeting at 7am so i'm going to sleep. I am really grateful for your help and input. Thank you thank you thank you thank you thank you. I appreciate it a lot. Edited September 23, 20233 yr by neanderthal
January 5, 20242 yr We had what sounded like a similar issue. For us, ALL streams would play for about 5 seconds, then the video would freeze for a fraction of a second and you would also hear an audio glitch (a "pop) and then the video would resume for about 5 seconds and then would glitch again. We were able to fix this. For the Buzz app, I forced-stop. Then cleared cache. Then cleared data. This fixed the issue I described. PLEASE NOTE, that these instructions will also wipe out all saved info like server info, favourites, settings, etc.
January 5, 20242 yr 59 minutes ago, jellytotz said: We had what sounded like a similar issue. For us, ALL streams would play for about 5 seconds, then the video would freeze for a fraction of a second and you would also hear an audio glitch (a "pop) and then the video would resume for about 5 seconds and then would glitch again. We were able to fix this. For the Buzz app, I forced-stop. Then cleared cache. Then cleared data. This fixed the issue I described. PLEASE NOTE, that these instructions will also wipe out all saved info like server info, favourites, settings, etc. just back those up first
