June 28, 20233 yr HELP - One {TV5} - says wrong user name password second {TV&} says it can not load ... I changed nothing ANY ideas ??? Could thins mean my reseller was sketchy? ANY HELP APPRECIATED
June 28, 20233 yr could be many things. if it was working fine and you changed nothing then maybe yes or no. yes if they are not answering you anymore. no because your credentials might have compromised also, check your internet is fine and your ip is not banned.
June 28, 20233 yr Try rebooting both your Modem and/or Router. Even if it all seems fine, you should try it. And try to contact your reseller to see if there is any known issue with the service, or if you account has been flagged maybe.
