June 20, 20233 yr I suffer from a lot of lag and passing. It only works with ethernet. It does not connect to wireless. Can anyone help?
June 20, 20233 yr What router are you using ? Does your router allow you to disable "band steering" (some call it differently). Basically to allow you to separate 2.4Ghz and 5Ghz band, instead of allowing the router to announce one SSID and have it decide what to use.
June 20, 20233 yr Author I have a regular internet router from EE (UK). I am not savvy about band with
June 20, 20233 yr Author Here is the data: Router IPv6 status: Enabled IPv6 network status: Disabled IPv6 WAN details Global unicast address: Not available http://192.168.1.254/images/u686.png http://192.168.1.254/images/context_help_icon_u703.png Global unicast prefix / length: Not available Link local address: Not available Remote link local address: Not availablehttp://192.168.1.254/images/context_help_icon_u703.png DNS: IPv4 Only IPv6 LAN details Global unicast address: Not availableULA prefix / length: Not available http://192.168.1.254/images/u686.png http://192.168.1.254/images/context_help_icon_u703.png
June 20, 20233 yr Unfortunately most all-in-one modem/routers provided by the ISP are usually not that great for WiFi (even here in North America). They are super basic and are barely up to the job. The setting you are looking for, would be under the "Wireless settings". There is nothing WiFi in the settings you posted above. It would something with the 2.4Ghz and 5Ghz bands. Having said that, I myself have a more commercial grade setup at home ,but even then, for most of my media boxes ,I always have them wired, it is just more stable.
