Recordings not found
Just recently purchased my Buzz 5 Classic and set up to record several programs. The recordings showed up in Recordings but when I clicked on a program is indicated "No recording found". Tried several more time with same results.  Am I doing something wrong or not doing something that I should?
I did not set up the recording location, in fact I did not find PVR options under menu.
I set up several custom recordings that still appear every day in PVR with the message "No recording found" when I click on it.  I have tried to delete those custom recordings but can't find a way to do this.  Seems like a major discrepancy and it is not endearing me to Buzz 5 TV.
While in LiveTV, if you press the menu button (top left of the DPAD on the remote), you will see a menu show up on the left.  From there, you should have an option saying "PVR Options".
when you go to recording the bottom toolbar shows you how to delete
It shows me how to delete a recording but NOT how to delete the custom recordings. Thus I keep getting these recordings that appear but have no content.
go to scheduled recordings
