No sound in pvr recordings
When recording with pvr I get no sound/audio on playback? I've tried resetting the device back to its default state thinking it may be an incorrect setting but still nothing.
It doesn't matter if I'm recording to the internal storage or using a USB flash drive or USB hdd. What else could it be?
what are the audio options when you hit green button for audio while pvr is playing?
1 minute ago, Anglishplz said:
It says audio is disabled with a check mark by it, I can't uncheck it.
try the other player
