Features eg Miracast and casting
builtin miracast does not work but third party apps works fine. I tried one ApowerMirror app and worked fine.
1 hour ago, Scuba1900 said:
Has anyone got casting to work efficiently on the xrs 4900 ?
I mentioned it to buzz and they were going to check it
It definitely will not work with Samsung devices
I have tried with one plus mobile, Huawei  and also a laptop using chrome and also had issues.
try ApowerMirror and let us know
The issue with the version of Miracast app is its very old
And with the newer phones + android versions that have come out over the years, am sure the protocols + apis etc are outdated
I think we will consider removing Miracast in our next update, to avoid complaints and bad customer experience.
I agree with you. Thanks 🙂
Or just place here in the forum to upgrade to the latest Miracast ?
Can you share which Miracast software was installed ? Can this be upgraded from the play store ?
It was provided by Amlogic
So its a system app
So they do not update it on the PlayStore.
There are tons of other Miracast apps on the Playstore
So am not sure which one to recommend
