June 5, 20215 yr 1 hour ago, Scuba1900 said: I got a message that it would stop recording . I am looking for a provider that would offer that service . there is no server discussion allowed here Pm sent
June 13, 20215 yr Author I need help I had it recording. Played shows back worked good. The next day I tried to back same recordings and the all showed up but when you click on them says nothing recorded? Frustrated in Pennsylvania.
June 21, 20215 yr On 6/12/2021 at 9:40 PM, Robert said: I need help I had it recording. Played shows back worked good. The next day I tried to back same recordings and the all showed up but when you click on them says nothing recorded? Frustrated in Pennsylvania. I only record when the channel is being viewed otherwise it cuts off for me
June 21, 20215 yr 2 minutes ago, Scuba1900 said: I only record when the channel is being viewed otherwise it cuts off for me are you trying to watch a different channel while recording another?
July 4, 20215 yr Author Will a future update let us record on one channel while watching another channel?
July 4, 20215 yr depends on your server if your server has that feature to record one channel while watching another.
July 4, 20215 yr 35 minutes ago, Robert said: Will a future update let us record on one channel while watching another channel? it already can do that
July 4, 20215 yr 1 hour ago, Ryu said: depends on your server if your server has that feature to record one channel while watching another. Not quite. It won't work with mac addy even if server allows more than one connection
August 18, 20215 yr On 7/4/2021 at 1:52 PM, nbs. said: Not quite. It won't work with mac addy even if server allows more than one connection Hmm well it kind of defeats the purpose doesn't it ?
August 18, 20215 yr 1 hour ago, Scuba1900 said: Hmm well it kind of defeats the purpose doesn't it ? I think it's to prevent users with only one connection from getting banned
