May 12, 20206 yr yes with the xpl3900, the arq100 air mouse. I might have an xpl3000 somewhere lying around, would i be able to use that mouse somehow?
May 12, 20206 yr I must be wrong about remote not working Otherwise the guide would be wrong Is this a brand bew set up?
May 12, 20206 yr if i can find that box i'll give it a try..although i'm not sure if the xpl3900 has a built in receiver for the signal of the remote, and wouldn't I then need to program the remote?
May 12, 20206 yr most remotes do not need the file i asked are you setting it up for first time ? you have two batteries installed
May 12, 20206 yr everything has been setup, just having an issue with box booting up, keeps looping on startup screen then freezes. i was forwarded by mygica support to this forum.
May 12, 20206 yr batteries are installed in the usb remote, about to look for my xpl3000 to see if i can get a hold of that remote.
May 13, 20206 yr 17 hours ago, nbs. said: heading out ,good luck thanks for you help with this, I wasn't aware the buzz remotes were universal, everything worked out perfectly and box is fully functional.
