April 5, 20215 yr I have this issue "media format is not supported" on multiple channels. I have tried both players same result. The issue does not happen on the xrs4500 using same provider. another problem with the Buzz TV 5 is the PVR scheduled recordings. You can't change the frequency or channel when in record mode. No problem to do that on the xrs4500 hopping for a fix as I record every day . you have to go to the channel every day to setup multiple recordings and if there is no epg you are out of luck
April 5, 20215 yr 5 minutes ago, ger482 said: I have this issue "media format is not supported" on multiple channels. I have tried both players same result. The issue does not happen on the xrs4500 using same provider. another problem with the Buzz TV 5 is the PVR scheduled recordings. You can't change the frequency or channel when in record mode. No problem to do that on the xrs4500 hopping for a fix as I record every day . you have to go to the channel every day to setup multiple recordings and if there is no epg you are out of luck What do you mean cant change the frequency on recordings? And you cannot change the channel while recording if the server you're using only allows 1 connection. This is the same on the 4500 as well. You can setup manual recordings on channels with no epg, by just pressing the Record button on the EPG for the channel you want to setup for manual recording. As for media not supported, PM me about this.
April 5, 20215 yr if you have only one connection you can change the channels but it ends the recording
