February 7, 20215 yr For the last month, time shift function does not work anymore on my XRS 4000. When I select an available show on a channel that indicates time shift available, it lags and lags without displaying any image. I decided to install stub emu pro on my box using the same server and time shift works perfectly... I have the latest release of BuzzTV 4. Before holidays, it usually worked properly. What can I do since I prefer the interface of BuzzTV to stub emu pro?
February 7, 20215 yr Author I made 3 factory reset s and it did not anything. I am using the default player: secondary,,, Where can I empty the cache? In advanced settings? Under applications ?
February 7, 20215 yr Author Ok, I found out for cache, No change after I emptied it. I changed the player as well to default,. Same thing; no change. Time shift still not working with ByzzTV 4 but perfect with stub emu pro.
February 7, 20215 yr 1 hour ago, JP Tremblay said: Ok, I found out for cache, No change after I emptied it. I changed the player as well to default,. Same thing; no change. Time shift still not working with ByzzTV 4 but perfect with stub emu pro. time shift worx for me using buzztv 4
February 8, 20215 yr 4 hours ago, JP Tremblay said: Ok, I found out for cache, No change after I emptied it. I changed the player as well to default,. Same thing; no change. Time shift still not working with ByzzTV 4 but perfect with stub emu pro. you need to pm alboutbuzz with your info to figure out the issue
February 8, 20215 yr 16 hours ago, nbs. said: you need to pm alboutbuzz with your info to figure out the issue Yes please do this
