January 24, 20215 yr Cannot pair error while try to pair Bose QuiteControl 30 headset to XRS 4000 device. Tried couple of time factory reset, didn't help always get "Cannot pair" error and then "Bluetooth keeps stopping" message
January 25, 20215 yr 22 hours ago, snan said: Cannot pair error while try to pair Bose QuiteControl 30 headset to XRS 4000 device. Tried couple of time factory reset, didn't help always get "Cannot pair" error and then "Bluetooth keeps stopping" message We have a few boxes here that were debugging with this issue We will fix it and then release it as an update.
March 14, 20215 yr XRS 4000 Bluetooth error when pairing speakers. Cannot pair error while try to pair speakers to XRS 4000 device. Tried always get "Cannot pair" error and then "Bluetooth keeps stopping" message. XRS 4000 Firmware Version #20201219
March 15, 20215 yr We had to get a few users local to us to lend us their 4000s with this issue. As this issue has been difficult so far to fix, as its only happening to a small amount of users Were going to spend next week debugging this and then try to fix it.
May 27, 20215 yr I am trying to enable bluetooth on XRS 4000 for my remote and get error pop-up "Bluetooth keeps stopping". Is there any workaround for this ? Bluetooth version is 9
May 27, 20215 yr 3 hours ago, salagian said: I am trying to enable bluetooth on XRS 4000 for my remote and get error pop-up "Bluetooth keeps stopping". Is there any workaround for this ? Bluetooth version is 9 do you have any other bluetooth devices nearby?
May 28, 20215 yr My TV is the closest to the setup box but it needs BT for remote. I have moved it to different locations and have same issue.
August 2, 20215 yr After updating firmware on my XRS4500 MAX to V20210723, My bluetooth keeps stopping. I have an ARQ-100 remote as well. I tried a reset, cache and data clear still same problem.
August 3, 20215 yr 17 hours ago, Veo said: After updating firmware on my XRS4500 MAX to V20210723, My bluetooth keeps stopping. I have an ARQ-100 remote as well. I tried a reset, cache and data clear still same problem. PM me thanks
November 22, 20214 yr Unable to connect my Boltune headphones to my BuzzTV box. Am I doing something wrong or is this box not capable of bluetooth audio connection with headphones?
November 22, 20214 yr It works with most devices but with thousand on the market there will be some that don't work Are you pairing under remotes and accessories?
November 22, 20214 yr Yes. Under remotes and accessories. It can see my headphones but then says can't connect and the Bluetooth screen crashes.
November 22, 20214 yr Tried with the wifi off. Same issue. Sees my headphones but won't connect and then Bluetooth crashes
