YCbCr settings changed. TV doesn't recognize signal
Received my vidstick today and tried playing around with the color settings in the advanced menu. After changing the YCbCr settings, the videosignal is not recognized by the TV and I can't access it. Have tried reset via pin hole, but no luck.
Any ideas?
Any ideas?
You have to put the pin in and hold it  then power on stick and keep holding it until android recovery menu appears
I have held it, put power in and kept holding it for up to one minute. Recovery menu does not appear. There is power to the stick as the light on the back is turned on
Solved, I had some strange HDR setting on the TV which f'ed up the signal. When turning it off the signal went through and recovery mode menu appeared.
