Ipguys not working on buzz tv
For some reason ipguys is not working on the buzz tv xrs4500
its on panel 3
is there a different url that you have to use on buzz tv because the same code is working on mag
its on panel 3
I just got a trial and it works fine
Works fine for me as well.  Have you tried unplugging the box, then rebooting?
"Not working" isn't very specific ..
