24 hour format to 12 hour format?
When you setup a recording in the PVR menu is there a way you can change the time format from the 24 hour format to a 12 hour format?
12 hours ago, dishuser said:
you have to do that in settings/date & time
I have that set to 12 hour format in date & time, but that doesn't change it to 12 hour format in the manual recording settings.
When you setup a  manual recording the time format is still 24 hour format, I would like to change that to the 12 hour format also but I can't seem to find a way to change it.
