January 12, 20233 yr Is there a way I can watch shows saved on my U5 PVR on a tablet in another room of my house (on the same local network)?
January 12, 20233 yr Nothing out of the box. The files are stored directly on the U5 storage device and it is not shared to external (no integrated SMB server). And even if it was, there would not necessarily be an easy way to determine what each recorded file was since the naming convention is not really too obvious, and the relationship of filename to actual program description/contents is in another file which the BuzzTV app uses.
January 24, 20233 yr Author That's too bad. Might there be a way to remotely program the PVR? It would be great if the U5 had a web interface that was at least accessible from a browser on a computer on the same LAN.
January 24, 20233 yr you can use TeamViewer from your pc to your box to remotely do some work and transfer files. 🙂
