January 8, 20233 yr Weird moved the box to a different room, plugged everything in, now no power !!!! Tried everything!
January 8, 20233 yr sorry what i was going to post was for another box Edited January 8, 20233 yr by gig63
January 9, 20233 yr 2 hours ago, Rinny1 said: Weird moved the box to a different room, plugged everything in, now no power !!!! Tried everything! even moved the ps?
January 9, 20233 yr 16 minutes ago, Rinny1 said: Yup weird tired everything no go !!! so no light on box? and you've tried different input/source? Edited January 9, 20233 yr by dishuser
January 9, 20233 yr And you are sure the outlet has power ? Strange. If you move it back to original location, with original cable and stuff ?
January 9, 20233 yr Author correct no light on the box When home I’ll test for power on the power source etc Thanks Edited January 9, 20233 yr by Rinny1
January 9, 20233 yr The E5 uses a USBC power input. So if you have a USB charger from an android phone or tablet, you can probably use that to try to power the box also.
January 9, 20233 yr Author Interesting the blue light on now no idea 🤷🏻♂️ what happened!! Working now
