October 27, 20205 yr Remote doesn't work any longer with stick. Not a battery issue. It has somehow unpaired. Followed instructions on back of remote with no luck. Help!!
October 28, 20205 yr Author There is no IR cable that I am aware of. It only came with an HDMI cable. Never needed a cable?
October 28, 20205 yr 3 hours ago, Tim Haines said: There is no IR cable that I am aware of. It only came with an HDMI cable. Never needed a cable? The vidstick comes with an IR sensor cable .You plug it into the stick and your remote will work as an ir remote
