September 8, 20206 yr I seem to cut the recording off half way through , I can't seem to find any instructions any where on how to use pvr can you help? Thks James
September 9, 20206 yr On 9/7/2020 at 10:43 PM, mopar.man said: I seem to cut the recording off half way through , I can't seem to find any instructions any where on how to use pvr can you help? Thks James What are you recording to, USB, SD Card or internal storage? If its USB or SD Card, sometimes users have these formatted to FAT32 Which cannot create files larger then 2GB 2GB would be about 1-2 hours worth of recording, depending on the channel quality It is suggested that your USB or SD Cards are formatted to NTFS for recordings.
