August 20, 20206 yr Hello , I just received my Stick , was using formuler box before (had all tv ,movies,series fine) however with stick 4000 only getting live and movies but no tv series. Btw i'm using the same service on formuler and still loading tv series fine hope i can heard from the Team asap Regards
August 20, 20206 yr Author 19 minutes ago, dishuser said: when in live tv are you selecting menu? What do you mean exactly ? Just now, nbs. said: Some servers dont have TV series or they put it in vod but i get it with the same server on my formuler and been working fine over 3 years i just bought the stick has i heard good things about it and want try it but doesnt load tv series and this is an issue for me . how can we solve it ? has i'm using same portal for both formuler/stick . so is 100% from the stick, how i can fix ? Regards
August 20, 20206 yr PM me the server name please Dishuser is asking you to hit the menu button while you are watching live tv then select tv series from there
August 21, 20206 yr I have confirmed its a buzz/server conflict as tv series do not even show up in menu
