Cable connection instead of wifi
Currently I use wifi but am wondering if I can use old cable tv connection between modem and android instead of wifi. What is needed to do this, if it can be done.
You need an ethernet cable between buzz and modem
You could look up powerline adapters
What's the issue with your wifi?
3 hours ago, Ron Zsombor said:
Picture freezes momentarily on higher number channels.
I think is the server problem,or try to change the player
You could install speedtest or some program like that to test your internet speed on wifi, but the powerline solution is also a viable solution.
