July 16, 20206 yr Hi All My friend and I had buzz xpl 3000, and we just both recently updated to the new XRS 4500. Wow, much faster and loads quick. The only question we have is with the recording. I have seen on sites, that the box can be shut down, and recording will work. My friend tried, and did not work. Or do we select option of suspend rather then shut down. If anyone can help. Much appreicated.
July 22, 20206 yr Author Ok, I agree. Thanks again. Just was hoping it would work, rather keeping box on, as many posts indicated it would. Oh well, good to know.
August 21, 20206 yr Recording when XRS4500 is off works fine for me. I am using external storage plugged into USB3 port. Also working when I was using internal storage. When off, device will not indicate recording in progress but it will record manually scheduled recording session. Model: XRS4500 Version: 9 Android security patch level: 5/5/2020 Kernel: 14.9.113 Build: 20200624.20200624 test-keys
