November 26, 20223 yr We have an E 2 SE , It is connected to Samsung Smart Tv . When I start both devices up the TV does not remember the buzz device , it remembers the computer and the other X 88 pro but not the Buzz box . I turn the Buzz box off after using it . is there anything we can or should do to address this issue? Thanks in advance
November 26, 20223 yr try to label your input as a cable box or something. I had same issue with Samsung tv but once I labeled it on input and tv remembers it now. you may have to start from scratch.
