November 1, 20223 yr wondering if anyone else is having these issues, after the most resent big firmware upgrade, the 4900 will on record any all all progams for only 30 minutes and then cuts off, was able to record all programs fully before, also, the catch-up feature with my provider, for all shows and hours, will now cut off and stop 30 seconds before the show is done, can someone confirm if this is a provider issue, or a firmware issue on my box, as other users with my provider are not experiencing the same issue, and lastly, does anyone knoe of a future feature on the box, or any future upgrades, for a "delete all for Recordings" be added to all recorded programs, instead of deleting one by one, thanks
November 3, 20223 yr 39 minutes ago, steelerzz said: Yes!! nbs. wasn't asking since you already confirmed that in first post 😉
November 3, 20223 yr 1 hour ago, Frost bitten Canadian said: Seems to be a common problem. Hopefully it gets sorted out... if it was a "common" problem there would be more than a couple of posts about it
November 19, 20223 yr Just tried recording a hour program and it does stop after 30 mins…hmmm. Strange
November 19, 20223 yr 9 minutes ago, BigLife said: Just tried recording a hour program and it does stop after 30 mins…hmmm. Strange then you're doing something wrong
November 19, 20223 yr 11 minutes ago, BigLife said: Just tried recording a hour program and it does stop after 30 mins…hmmm. Strange last few weeks I have recorded more than 4-6 hours long and box recorded perfect and not only that couple of them recording box did it when it was off. everything worked great. 🙂
November 19, 20223 yr 28 minutes ago, BigLife said: Just tried recording a hour program and it does stop after 30 mins…hmmm. Strange Post your buzztv version
