October 29, 20224 yr Any one else knows how to get the xrs 4900 remote to put on the device from an off position ?
October 29, 20224 yr does light blink on remote when you press power button? go to settings, remote and accessories, do you see remote in the list and does it says connected? if not try to connect or go to settings, buzz utilities, power options, default
October 29, 20224 yr 49 minutes ago, Scuba1900 said: Any one else knows how to get the xrs 4900 remote to put on the device from an off position ? press the stb button
October 30, 20224 yr 51 minutes ago, Scuba1900 said: Already like this . The issue I feel is with the firmware upgrade my 4900 turns off and on using stb button running 5.0.783
October 30, 20224 yr 48 minutes ago, dishuser said: my 4900 turns off and on using stb button running 5.0.783 So does mine
