June 15, 20206 yr Tried to load an m3u list and it's stuck on "loading channel list" this notice shows up on Buzztv, livetv, vod, and tv series which makes it impossible to get into those programs. I've re-booted and nothing I've tried can correct this, I'm trying to avoid a "hard reset". I have a lot of time getting everything loaded and I would prefer to not go through it again. Any help would be appreciated.
June 15, 20206 yr Can you go home,server settings m3u ,then edit line.? Edited June 15, 20206 yr by nbs. Spelling
June 15, 20206 yr So you can get to server settings then it tries to connect without you hitting connect button?
June 15, 20206 yr Author In settings it shows the "server" box, when you click on it the "loading channel list" will appear and the loading rotation sign will be turning like it's trying to load but it never loads.
June 15, 20206 yr do you have a USB device inserted into the VidStick ? If so, remove that and see if any difference.
June 15, 20206 yr Author No USB, I did try removing my sandisk card and that didn't change anything either.
June 15, 20206 yr Not sure exactly where you are in all this. Are you trying to connect to an M3u slot ? Is that slot setup with a Playlist URL is is it a hard copy of a m3u file on a memory device ? Or did you abandon that and are now trying to connect thru a Server slot with a MAC attached ? Please explain more clearly where you are at 🆒
June 16, 20206 yr 4 hours ago, Pierre said: In settings it shows the "server" box, when you click on it the "loading channel list" will appear and the loading rotation sign will be turning like it's trying to load but it never loads. I didnt want you to click on it I wanted you to hit the blue button to edit the info in server so you could start fresh
June 16, 20206 yr Author nbs., There isn't a blue button to hit??? What screen mode are you referring to? Whacked, It's explained above your input. I'm locked out of my servers and unable to get at the m3u loader.
June 16, 20206 yr Author I've checked all 3 home screens and there is no blue button. My stick is a week old, I should say I received it a week ago.
June 16, 20206 yr When you highlight the m3u line that you are using there should be an icon at the bottom of screen saying edit It should be blue.Whether or not the button is blue it is the bottom right button on your remote that you should use as dishuser stated. Edited June 16, 20206 yr by nbs.
June 16, 20206 yr Author Thank you, one and all!! The word "remote" was the key to solving this issue. The blue key lets you edit the current display but but the original command stays loaded. BUT....the red key on the bottom left of the remote allows you to erase the original command that was trying to load. Problem solved!!!!
