issues with wifi pn the Buzz TV ST4000
Hello I'm having issues with the Buzz TV st4000  Wifi in which i'm unable to get bandwidth speeds pass 67 Mbps on a 200Mbps plan. However I have factory reset this device about three times but issue still persists
hrmm do not have a stick, but are you sure you are connected to 5ghz on your wifi? seems like its stuck on 2.4ghz?
are you getting 200 on other devices?
For accurate speedtests that are not owned by ISP's and largely Fake, use Fast dot com which is owned by Netflix.
