Remote controller doesn't pair
Hello,
My remote controller doesn't work correctly anymore. It begans when the controller became so slow. I had to wait 5 seconds between each push of  button.
I tried to do a factory reset but when it ask me to pair the controller , it was impossible. The XR4500 is scanning but it doesn't found my remote controller.
The remote work in IR  but it's very slow.
What should I do?
Use the contact form at getbuzz dot TV
See what they say
What version of buzz 4 are you on?
See what they say
the last one. I check daily if the are updates
Yes , the lastest available OTA
Firmware Version: V20200319
Buzz 4 App Version: 4.0.437
PS : I sent an email to the seller but I still have no response
Edited by lexapa001
