September 6, 20224 yr Hi, I’m a newbie to BuzzTV boxes, I have just bought the xrs4900 and am very impressed with it so far. One question I have is regarding the usb-c connection on the back of the box. It says it is for data but any drive or ssd I connect is not recognised. Should it be able to read/write to a drive connected to that port or am I completely off track with what the connection is for. I have an ssd connected in the compartment and that is working fine it’s just the usb-c connection that I am unable to get anything working on. Any help appreciated, thanks.
September 6, 20224 yr 7 minutes ago, Macca24 said: Hi, I’m a newbie to BuzzTV boxes, I have just bought the xrs4900 and am very impressed with it so far. One question I have is regarding the usb-c connection on the back of the box. It says it is for data but any drive or ssd I connect is not recognised. Should it be able to read/write to a drive connected to that port or am I completely off track with what the connection is for. I have an ssd connected in the compartment and that is working fine it’s just the usb-c connection that I am unable to get anything working on. Any help appreciated, thanks. Its to be used with a PC It allows you to grab any data that is on the Hard Drive you have installed on the box.
September 6, 20224 yr Author OK thanks, so I can’t connect an external hard drive then? That’s a shame I thought that’s what the connection was for. No worries it’s still a great box.
September 6, 20224 yr 3 minutes ago, Macca24 said: OK thanks, so I can’t connect an external hard drive then? That’s a shame I thought that’s what the connection was for. No worries it’s still a great box. there's 3 usb ports on the side
