August 31, 20224 yr Hi. I have a few xrs 4500 boxes. But one box in particular. The blue led emblem on the box remains blue after turning it off. On my other 2 boxes it turns red. Any idea how to fix this?
August 31, 20224 yr what firmware/software version do you have? are all at same versions? are all set to same powerkey definition?
August 31, 20224 yr Author Firmware V20211108 IPTV version 4.0.530 Power button setting is suspend. Yes they are all the same.
August 31, 20224 yr you should consider updating to buzztv beta5 current iptv version is 5.0.763 if you want update pm allaboutbuzz all the server id's
September 6, 20224 yr On 8/30/2022 at 10:46 PM, Dereck said: Hi. I have a few xrs 4500 boxes. But one box in particular. The blue led emblem on the box remains blue after turning it off. On my other 2 boxes it turns red. Any idea how to fix this? It usually means there is a background app running that Android cannot close when put into standby.
October 4, 20224 yr Author Thanks. That's probably it. The light on the box now turns red after I turn it off.
