April 27, 20206 yr does anyone know if you have an XRS4000 if you can simply transfer the settings and apps etc.. over to the XRS4500? this way you don't have to completely rebuild the unit? if its possible any advice how to go about doing this. thanks.
April 27, 20206 yr Not sure if you loaded the backup of a 4000 to a 4500 if it would work. Wait for allaboutbuzz to confirm
