April 18, 20206 yr I have a new XRS4500. I have been trying to set the screen resolution to auto switch to best resolution. When I am in advanced settings-Display-screen resolution and I try to set the switch to auto the screen of the XRS goes blank and I have to turn the unit off and back on to get the picture back. When I check to see if the resolution is set to auto it is not. How do I do this?
April 18, 20206 yr there seems to be a glitch which will be fixed It wasnt an issue when i set my box up The same thing happened to me when i turned it off and tried to turn it back on I might have a workaround for now after the screen goes black wait a few seconds,then hit the right arrow button and then ok
April 19, 20206 yr Author Thanks for the advice. I tried the suggestion but it did not work for me either. Hopefully there will be a fix with a new firmware update.
