management of storage
The storage on my device is almost completely used. I would like to know if some content can be moved to a USB or SD? If so, what content can be moved, and how is this done?
Did you record stuff to your box before?
Or download a lot of apps or movies?
I have not recorded anything to date but I have downloaded several apps, and I am assuming that this is the issue. I have almost consumed all the storage, so I am hoping that offloading apps to a USB will improve things.
have you tried file manager?
you select what you want to move and to which device
whether it be device to sd/usb or vice versa
options are at the bottom of the page
I will look at it more closely, thanks.  When I have used a USB in conjunction with a media box, it was strictly to store a downloaded movie. (Never tried to play the video from my media box.)
 If I were to move apps from the device to the USB, will this affect the functionality of the media box (ie launching the apps)?
