April 5, 20206 yr How do you skip to the next/previous track using only the remote control? Using the IR-100L remote and it only has fast forward/rewind buttons however most remotes I see for BuzzTV devices don't seem to have these buttons on them forcing you to use the on screen display. Thank you in advance
April 6, 20206 yr On 4/5/2020 at 2:27 AM, Guest Ryan S said: How do you skip to the next/previous track using only the remote control? Using the IR-100L remote and it only has fast forward/rewind buttons however most remotes I see for BuzzTV devices don't seem to have these buttons on them forcing you to use the on screen display. Thank you in advance Almost all of our BuzzTV remotes have the Fast Forward + Rewind Buttons. Unless am not understanding your question exactly... What next/previous track are you referring to exactly?
April 6, 20206 yr my understanding was he would like to skip to the next episodes.for example if watching 3 go to 4 or 5
April 7, 20206 yr 8 hours ago, allaboutbuzz said: Almost all of our BuzzTV remotes have the Fast Forward + Rewind Buttons. Unless am not understanding your question exactly... What next/previous track are you referring to exactly? I am looking to skip to the next track or file clip. Not fast forward / rewind
April 7, 20206 yr 6 hours ago, nbs. said: my understanding was he would like to skip to the next episodes.for example if watching 3 go to 4 or 5 Correct
April 7, 20206 yr 10 hours ago, Ryan S said: Correct Ok that makes more sense We currently don't have a feature like that Will look to adding it to the info bar with a colored button.
