Problem with "Bluetooth" Causing Glitchy Audio
Hello
My new Box just arrived but I am experiencing an audio problem whaich I believe is caused by the "Bluetooth".
Whenever I play for example my Radio Apk and I pair it to via "Bluetooth"  to my Sony Speakers the sound is nice and crisp.
But when I stop the radio and change it to watch a Live TV or another IPTV apk, the sound through the paired speakers become glithcy & distorted.
To fix I have to Unpair the Bluetooth hten Pair again.
Is anyone having this problem ?
Is there a FIX for this.
Thanks😒
Actually it is the XRS4500 MAX...but there was no Category in the dropdown menu for it, so I picked one
that's because all 3 versions of the 4500 use same software
is it a software issue ?
and is there a Fix ?
Thx
I am just a NewBee to this stuff ,🤓🤯
How can I get a copy of this Beta 5 Firmware.
More importantly, Would it run on the XRS4500 MAX  to correct this audio problem ?
Thx
which is the Best plat to PM  - FaceBook or Instagram ? Thx🧐
right here
go to home page and scroll down and on the right you will see allaboutbuzz
click on his username and select message
None of the above He is here...lol
