July 18, 20224 yr I can't get it update. Just says pending, restarted it, changed wifi, nothing. Just wondered if anyone else had that problem.
July 18, 20224 yr This is an issue with Google Services Try this Go to Settings -> Apps -> select Google Play Store from list -> select Clear data and confirm it. Do same for Google play services (it's under system apps list under Apps). This should fix issue.
July 20, 20224 yr On 7/18/2022 at 9:04 AM, Tomshafer said: I can't get it update. Just says pending, restarted it, changed wifi, nothing. Just wondered if anyone else had that problem. Any update to what I suggested to try on my post above
July 25, 20224 yr I just tried 3 times the first two times in google play store i clicked on update now and it just sat there doing nothing. The third time instead of clicking update now I clicked on android system web view which took me to another screen and then clicked update and it was successful Thank you for your time
July 25, 20224 yr Author On 7/20/2022 at 10:31 AM, allaboutbuzz said: Any update to what I suggested to try on my post above Sorry I just saw this now. I'm going to try it when I get home from work today. Thanks for your help, I'll post if it works.
July 25, 20224 yr Author 26 minutes ago, Tomshafer said: Sorry I just saw this now. I'm going to try it when I get home from work today. Thanks for your help, I'll post if it works. It worked!!! All updated. Thanks again.
July 25, 20224 yr Just now, Tomshafer said: It worked!!! All updated. Thanks again. Ok great to hear that
July 25, 20224 yr Author 33 minutes ago, allaboutbuzz said: Ok great to hear that Any news on when they're going to re-push the firmware update? Thanks
