VOD outdated and not current (2 to 4 days back)
I am having issue with VOD updates , it is 2 to 4 day old and not current episodes. for same server on other 3 Mag box has also up to date (current episodes)
is there any bugs or settings i need to change (sometimes it updates after rebooting but most of the time not)
I checked with service provider  and according them there may be something with the box as other Mag box has no problem
Please help
send the name of your server to allaboutbuzz
He will check into it
I have vod on 3 servers with no issues
Please help
This was fixed via PM
But I will list how here
If you have this issue
When in VOD
Press the menu button
Go to configuration
Scroll to the bottom and turn
Server Favorites On
Do a reboot and it will start to work
Majority of servers require Buzz app to save favorites to an internal database on the box. While a small amount of others have it stored on their server.
So we just put an on/off switch to make it work for ones with this issue.
