June 12, 20224 yr my xrs4900 is stuck in reboot mode, i can't get into menu nor the settings it just keeps rebooting over and over... any suggestions as to fix this issue? Thanks for any Help
June 12, 20224 yr 58 minutes ago, putski said: my xrs4900 is stuck in reboot mode, i can't get into menu nor the settings it just keeps rebooting over and over... any suggestions as to fix this issue? Thanks for any Help pin reset
June 13, 20224 yr Author Well I have tried this like 8 times over and over and still reboots not sure what the heck is going on...
June 13, 20224 yr 55 minutes ago, putski said: Well I have tried this like 8 times over and over and still reboots not sure what the heck is going on... when in recovery screen are you selecting wipe data? are you using the power adapter that came with it? cause the 4900 uses 12 v
June 13, 20224 yr 9 hours ago, putski said: Well I have tried this like 8 times over and over and still reboots not sure what the heck is going on... Are you getting to the recovery screen?
June 13, 20224 yr 9 minutes ago, nbs. said: And as dishuser asked are you scrolling to wipe data? I will have to check when I get back home.. I did just as the video showed. Should be back home in a couple hours.
June 13, 20224 yr yes i can wipe data / factory reset some times it reboots before letting me get the setup done. i have tried it many times.. but I'm going to try again.
June 17, 20224 yr You can load a file from recovery screen Worth a shot Ask allaboutbuzz for a link to the file
