XRS 4500 MAX TF Card size
Hi everyone, what is the biggest TF Card I can put in the XRS 4500 Max?
I want to buy a 1Terabit. Will this work okay?
Thank you for your support.
Mark7
Mark7
128GB
We haven't tried anything higher than this
So not sure if it will work.
Okay, thanks.
I can get San Disk Extreme 1 TB. If it doesn't work, I can use it in something else. Lotsa gadgets.
Thank you, Mark7
