April 27, 20224 yr I just received my E2 the other day and there are couple of things that nag me: - The channel display digits seem limited to 4 digits, i.e. in the guide it shows 12034 but at the bottom of the OSD it only shows 1203. - Is there any way to get the feed specs through Info or some other mean (i.e. we have no idea if the feed is SD/HD/FHD or 4K or if the codec is MP4 or HEVC). My previous box displayed that information when pressing Info a couple of times. Thank you. Edited April 27, 20224 yr by JC1
April 27, 20224 yr I have 3 or 4 digits in my guide and the osd is the same I also have stream info when I press info button
April 27, 20224 yr Author 29 minutes ago, nbs. said: Hit the menu button while watching tv and post the version info at bottom 4.0.524 January 18th 2022 The problem is that the provider has 5 digits channels. For the Info, all I get is first the bottom OSD and then I get the program description.
April 27, 20224 yr Pm allaboutbuzz and see if he can update your box to buzz 5 I dint know about your 5 digit channel listing Buzz 5 has the stream info
