December 25, 20196 yr Hi all, I have had the 4000 for some time. I cannot figure out how to stream anything other than 2.0. Can someone help to tell me if all the content is simply in 2.0 or am I not doing something properly.
January 2, 20206 yr 1 hour ago, mysetv said: You’ll find most streams are just 2.0 2 hours ago, Rpm said: Anyone? With mine I connect it to a home theater system and there if the stream or video with 5.1 the receiver of the home theater will do that for me 😁 ,I think for the 5.1 the box has to have a special chip 🙂👍
January 2, 20206 yr 19 hours ago, Rpm said: Anyone? Majority of streams from IPTV are in 2.0 Audio If you have a stream that is broadcast in Dolby or DTS, the Buzz app is capable of streaming it using Software Decoding through FFMPEG.
January 6, 20206 yr Author Interesting. My system is hooked up to a avr with atmos but I have yet to find a stream other than 2.0. And at that the audio is bad in comparison to the video
