April 5, 20224 yr Trying to connect new server and xrs4900 will not connect. Have confirmed mac address and url for portal are correct, but still will not connect. Suggestions?
April 5, 20224 yr Author Yes, the mac address starts 00:1A:79 and is connected to the internet and working. We have successfully connected with a 2nd server.
April 5, 20224 yr Author No, not sure how you would do this, with mac address and url from service provider?
April 5, 20224 yr also, try to clear cache and app data and see if that helps. becarfull as clear data will delete all saved portals info.
April 6, 20224 yr Tested It on a 3900,says not activated or expired You need to talk to your service Heather Edited April 6, 20224 yr by nbs.
