Problem with audio micro freezing
The video is not freezing but the audio is freezing like crazy unable to watch happened after the new update it was fine before the update and it's fine on my other boxes with the update. It's happening on the xrs4000
  • 3 weeks later...
On 12/21/2019 at 7:24 PM, Entertainmentoasis said:
Yes it's on both players. Rebooting the box seemed to resolve it. But it's done it twice on the same box
can you use "File Manager +" and check how much space you have on the box, because something this freezing or out of sync can happen when you have no available space for cache, maybe you have recordings on the unit, if you do move them to a SD card or USB thumb-drive or External Hard Drive.
