March 14, 20224 yr since update 653 on Xrs 4900 I noticed when on epg guide I scroll one at a time and it will start moving so fast you cannot read them! The remote button is not stuck. When this happens I cannot stop it, it will stop on it's own. Everything else is working great Edited March 14, 20224 yr by Rodie Forgot to add
March 14, 20224 yr Author 40 minutes ago, nbs. said: Check your battery level It will happen to me when it's low Hi nbs just checked batteries with meter showing 1.40 volts Also remote light is off
March 15, 20224 yr Mine does this even though battery percentage is in the 60s but not too often. Like once in a blue moon
