Audio Sync
Hi I got audio sync problem (audio legging about 1 to 2 sec ) on live channels , i tried Default and secondary player  but same issue
Default player get more often and more legging vs Secondary Player
any suggestion or settings?
Try today's update to see if the problem gets resolved.
It happens on all the channels?because I have this problem to on some channels but is from the server is not from the Buzztv players
Same here. And it happens on different players on the same channel. So it must be the server.
Seams like the default player is a problem, yes is getting out of sync more often ,the secondary player is the right option right now
some channels but same on other server, default and 2nd player both has the same problem
Model 3900 has the same but when you use 2nd or 3rd player it solves the problem
After recent update i do not see any audio sync problem, but i have not play enough , hope it solved
i will updates you next week
so far no audio leg issue  (audio sync)tested for 4 days
Edited by G2P
