February 10, 20224 yr My mouse does not work…just creeps along not float as it should. Why? Tried update and type in 2012 as well. Bluetooth is on and I have to use it because the stick is in the back of the tv. Please help anyone.
February 10, 20224 yr its 2015 not 2012 Doesnt matter if your stick is behind tv Plug in your ir extender so your remote can see it
February 10, 20224 yr 2 hours ago, Maddogg said: My mouse does not work…just creeps along not float as it should. Why? Tried update and type in 2012 as well. Bluetooth is on and I have to use it because the stick is in the back of the tv. Please help anyone. you can change mouse speed settings/device preferences/keyboard & autofill
February 10, 20224 yr Author Thank you for mouse up date. I set the mouse to max speed. Works great. I had hoped for a floating mouse like my Mygica but this will do. How do I get Buzztv 5 beta update? I saw the download but how do I get it on my Buzztv stick max? Thanks.
February 10, 20224 yr 30 minutes ago, Maddogg said: Thank you for mouse up date. I set the mouse to max speed. Works great. I had hoped for a floating mouse like my Mygica but this will do. How do I get Buzztv 5 beta update? I saw the download but how do I get it on my Buzztv stick max? Thanks. if you want a floating mouse get the arq-100 remote
February 11, 20224 yr A few days ago my buzz tv vidstick automatically updated and now it doesn't even turn on. Nothing comes up the screen is just blank.
February 11, 20224 yr 2 hours ago, Ryu said: have you tried reset with toothpick? Yes I did nothing works
February 11, 20224 yr 15 minutes ago, Sevonne Robinson said: Yes I did nothing works you held button down and then applied power while still holding button down?
February 11, 20224 yr 5 hours ago, Sevonne Robinson said: A few days ago my buzz tv vidstick automatically updated and now it doesn't even turn on. Nothing comes up the screen is just blank. try to reseat hdmi cable or take out stick from tv and reinsert or try different hdmi port and see if thet helps.
February 12, 20224 yr 7 hours ago, Ryu said: I switched around the hdmi and I tried the other ports it just says no signal Edited February 12, 20224 yr by Sevonne Robinson Made mistake when typing
February 12, 20224 yr how are you providing power to your stick? try usb if you are not using or if you are using usb then try direct from wall.
February 12, 20224 yr 1 hour ago, Sevonne Robinson said: I switched around the hdmi and I tried the other ports it just says no signal you never answered about reset
February 12, 20224 yr 23 hours ago, Ryu said: have you tried reset with toothpick? I holded the reset button for 10 secs but nothing worked
February 12, 20224 yr 21 minutes ago, Sevonne Robinson said: I holded the reset button for 10 secs but nothing worked post the steps you took
February 12, 20224 yr do you even feel click when you press? keep holding until you see the recovery screen.
February 13, 20224 yr Yes I felt the click but it didn't work when I pushed the button. Edited February 13, 20224 yr by Sevonne Robinson Did finish typing
