audio problem
I will be watching a channel for a few then my audio will cut out but video is fine, I can fix it by changing channel then come back?
Have you tried both media players?
Menu settings,config
no not yet, I have live tv set as default at the moment
Try secondary player see what happens but they've been some reports of this player behaving the same way.
Ok, I changed live tv to secondary and now the picture keeps freezing but audio continues.
It’s the server your using
I bet you try a different channel it’s fine
Mine don't freeze but it stutters/lag. It only happens on FHD channels.
Check the info bar bottom right hand corner where it says HD FHD SD. What does yours say on the channels that freeze up?
im using buzz  tv 5 and I dont see those on my info bar ?
Yes I see that info FHD and HD bottom right on the info bar
I’ll test out
you need to use secondary to see that
Never really had a problem on FHD channels
many problems server related
I didn't have any issues before the beta release. My channels streams have crisp picture, it doesn't say FHD for nothing 😂. It's as clean as you can get. But let's hope all things are ironed out soon
9 hours ago, Rinny1 said:
Ok
interesting
be sure allaboutbuzz knows
and your service was
Cant talk about services here, not allowed but it's good.
Bonjour
Ces normale avec la bêta il y a un problème de codec (ac3)
Fhd ou hd ces pas le problème regarder quel codecs déconne plutôt
Les deux lecteurs ne sont plus aussi bon
i have the same issue some channel audio works on default and some channels audio works on secondary. let me know if someone solve this problem.
buzz have to fix the issue ,its been posted about many times
ok , I will check back soon and see if there is a fix yet, i switch to t mate for now.
any updates on this issue yet ?
